Can anyone help me out with this one? I managed to flash another sd card but the error persists. I can log in via ssh. Heres is the debug:
0.5.4
Flashed OS version
v0.5.4-patch-1
Raspberry Pi Model
Revision : d03114
Serial : 10000000b6c14258
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=56.4’C
Throttling
throttled=0x0
Mem: 7.8G 135M 7.1G 8.0M 591M 7.6G
Swap: 4.1G 0B 4.1G
total: 1.7%
system: 1.7%
Memory monitor logs
2025-03-22 00:06:04 Memory monitor running!
2025-03-22 00:06:17 Memory monitor running!
2025-03-22 00:06:29 Memory monitor running!
2025-03-22 00:07:14 Memory monitor running!
2025-03-22 00:07:50 Memory monitor running!
2025-03-22 00:08:18 Memory monitor running!
2025-03-22 00:08:31 Memory monitor running!
2025-03-22 00:08:54 Memory monitor running!
2025-03-22 00:09:06 Memory monitor running!
2025-03-22 00:09:18 Memory monitor running!
/dev/root 60G 4.2G 53G 8% /
/dev/sda1 916G 825G 45G 95% /home/umbrel/umbrel
Startup service logs
Mar 22 00:09:18 umbrel umbrel startup[2249]: Starting status monitors…
Mar 22 00:09:18 umbrel umbrel startup[2249]: Starting memory monitor…
Mar 22 00:09:18 umbrel umbrel startup[2249]: Starting backup monitor…
Mar 22 00:09:18 umbrel umbrel startup[2249]: Starting decoy backup trigger…
Mar 22 00:09:18 umbrel umbrel startup[2249]: Starting umbreld…
Mar 22 00:09:18 umbrel umbrel startup[2249]: Starting Docker services…
Mar 22 00:09:20 umbrel umbrel startup[2249]: The TOR_PROXY_PORT variable is not set. Defaulting to a blank string.
Mar 22 00:09:20 umbrel umbrel startup[2249]: The TOR_PROXY_IP variable is not set. Defaulting to a blank string.
Mar 22 00:09:20 umbrel umbrel startup[2249]: The NGINX_PORT variable is not set. Defaulting to a blank string.
Mar 22 00:09:20 umbrel umbrel startup[2249]: The NGINX_IP variable is not set. Defaulting to a blank string.
Mar 22 00:09:20 umbrel umbrel startup[2249]: The DASHBOARD_IP variable is not set. Defaulting to a blank string.
Mar 22 00:09:20 umbrel umbrel startup[2249]: The UMBREL_AUTH_SECRET variable is not set. Defaulting to a blank string.
Mar 22 00:09:20 umbrel umbrel startup[2249]: The BITCOIN_P2P_PORT variable is not set. Defaulting to a blank string.
Mar 22 00:09:20 umbrel umbrel startup[2249]: The BITCOIN_RPC_PORT variable is not set. Defaulting to a blank string.
Mar 22 00:09:20 umbrel umbrel startup[2249]: The BITCOIN_RPC_USER variable is not set. Defaulting to a blank string.
Mar 22 00:09:20 umbrel umbrel startup[2249]: The BITCOIN_RPC_PASS variable is not set. Defaulting to a blank string.
Mar 22 00:09:20 umbrel umbrel startup[2249]: The BITCOIN_NETWORK variable is not set. Defaulting to a blank string.
Mar 22 00:09:20 umbrel umbrel startup[2249]: The MANAGER_IP variable is not set. Defaulting to a blank string.
Mar 22 00:09:20 umbrel umbrel startup[2249]: The AUTH_PORT variable is not set. Defaulting to a blank string.
Mar 22 00:09:20 umbrel umbrel startup[2249]: The AUTH_IP variable is not set. Defaulting to a blank string.
Mar 22 00:09:20 umbrel umbrel startup[2249]: The NETWORK_IP variable is not set. Defaulting to a blank string.
Mar 22 00:09:20 umbrel umbrel startup[2249]: The Compose file ‘./docker-compose.yml’ is invalid because:
Mar 22 00:09:20 umbrel umbrel startup[2249]: networks.default.ipam.config.subnet is invalid: should use the CIDR format
Mar 22 00:09:20 umbrel umbrel startup[2249]: services.tor_proxy.ports contains an invalid type, it should be a number, or an object
Mar 22 00:09:20 umbrel umbrel startup[2249]: services.auth.ports contains an invalid type, it should be a number, or an object
Mar 22 00:09:20 umbrel umbrel startup[2249]: services.nginx.ports contains an invalid type, it should be a number, or an object
Mar 22 00:09:20 umbrel umbrel startup[2249]: Failed to start containers
Mar 22 00:09:20 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Mar 22 00:09:20 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Mar 22 00:09:20 umbrel systemd[1]: Failed to start Umbrel Startup Service.
External storage service logs
Mar 22 00:08:03 umbrel external storage mounter[501]: Running external storage mount script…
Mar 22 00:08:04 umbrel external storage mounter[501]: Found device “T-FORCE 1TB”
Mar 22 00:08:04 umbrel external storage mounter[501]: Blacklisting USB device IDs against UAS driver…
Mar 22 00:08:04 umbrel external storage mounter[501]: Rebinding USB drivers…
Mar 22 00:08:04 umbrel external storage mounter[501]: Checking USB devices are back…
Mar 22 00:08:04 umbrel external storage mounter[501]: Waiting for USB devices…
Mar 22 00:08:05 umbrel external storage mounter[501]: Waiting for USB devices…
Mar 22 00:08:06 umbrel external storage mounter[501]: Waiting for USB devices…
Mar 22 00:08:07 umbrel external storage mounter[501]: Checking if the device is ext4…
Mar 22 00:08:08 umbrel external storage mounter[501]: Yes, it is ext4
Mar 22 00:08:08 umbrel external storage mounter[501]: Checking filesystem for corruption…
Mar 22 00:08:08 umbrel external storage mounter[501]: e2fsck 1.44.5 (15-Dec-2018)
Mar 22 00:08:08 umbrel external storage mounter[501]: umbrel: clean, 656473/61054976 files, 220344696/244190208 blocks
Mar 22 00:08:08 umbrel external storage mounter[501]: Mounting partition…
Mar 22 00:08:08 umbrel external storage mounter[501]: Checking if device contains an Umbrel install…
Mar 22 00:08:08 umbrel external storage mounter[501]: Yes, it contains an Umbrel install
Mar 22 00:08:08 umbrel external storage mounter[501]: Bind mounting external storage over local Umbrel installation…
Mar 22 00:08:08 umbrel external storage mounter[501]: Bind mounting external storage over local Docker data dir…
Mar 22 00:08:08 umbrel external storage mounter[501]: Bind mounting external storage to /swap
Mar 22 00:08:08 umbrel external storage mounter[501]: Bind mounting SD card root at /sd-card…
Mar 22 00:08:08 umbrel external storage mounter[501]: Checking Umbrel root is now on external storage…
Mar 22 00:08:09 umbrel external storage mounter[501]: Checking /var/lib/docker is now on external storage…
Mar 22 00:08:09 umbrel external storage mounter[501]: Checking /swap is now on external storage…
Mar 22 00:08:09 umbrel external storage mounter[501]: Setting up swapfile
Mar 22 00:08:11 umbrel external storage mounter[501]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Mar 22 00:08:11 umbrel external storage mounter[501]: no label, UUID=9ac449b9-65d0-48b7-abdc-d6bed4888b22
Mar 22 00:08:11 umbrel external storage mounter[501]: Checking SD Card root is bind mounted at /sd-root…
Mar 22 00:08:11 umbrel external storage mounter[501]: Starting external drive mount monitor…
Mar 22 00:08:11 umbrel external storage mounter[501]: Mount script completed successfully!
Mar 22 00:08:11 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Sat 2025-03-22 00:07:58 UTC, end at Sat 2025-03-22 00:09:26 UTC. –
Mar 22 00:08:17 umbrel systemd[1]: Starting External Storage SDcard Updater…
Mar 22 00:08:17 umbrel external storage updater[989]: Checking if SD card Umbrel is newer than external storage…
Mar 22 00:08:17 umbrel external storage updater[989]: No, SD version is not newer, exiting.
Mar 22 00:08:17 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
Tor Proxy logs
==== Result ====
