Raspberry Pi 4 - Error: Failed to start containers
Hi, Any help appreciated. After power down unable to access node, tried loads of terminal fixes - unsure if this had made things worse, reflashed sd card, etc but nothing seems to work, I think the password has reset to default, not a terminal user normally.
currently rasp pi4 green light occasionally flashes and disk seems to flash too. I can reset via terminal so there is some communication to the raspberry pi4.
If unable to fix this error- can I recover funds on the bitcoin node and start a fresh Umbrel node install?
0.5.4
Flashed OS version
v0.5.4-patch-1
Raspberry Pi Model
Revision : d03114
Serial : 10000000758f8fb8
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=58.4’C
Throttling
throttled=0x0
Mem: 7.8G 132M 5.6G 8.0M 2.0G 7.5G
Swap: 4.1G 0B 4.1G
total: 1.7%
system: 1.7%
Memory monitor logs
2024-12-21 07:34:16 Memory monitor running!
2024-12-21 07:34:28 Memory monitor running!
2024-12-21 07:34:40 Memory monitor running!
2024-12-21 07:34:51 Memory monitor running!
2024-12-21 07:35:03 Memory monitor running!
2024-12-21 07:35:15 Memory monitor running!
2024-12-21 07:35:27 Memory monitor running!
2024-12-21 07:35:39 Memory monitor running!
2024-12-21 07:35:51 Memory monitor running!
2024-12-21 07:36:03 Memory monitor running!
/dev/root 30G 5.1G 24G 18% /
/dev/sda1 916G 797G 73G 92% /home/umbrel/umbrel
Startup service logs
Dec 21 07:36:03 umbrel umbrel startup[11103]: Starting status monitors…
Dec 21 07:36:03 umbrel umbrel startup[11103]: Starting memory monitor…
Dec 21 07:36:03 umbrel umbrel startup[11103]: Starting backup monitor…
Dec 21 07:36:03 umbrel umbrel startup[11103]: Starting decoy backup trigger…
Dec 21 07:36:03 umbrel umbrel startup[11103]: Starting umbreld…
Dec 21 07:36:03 umbrel umbrel startup[11103]: Starting Docker services…
Dec 21 07:36:04 umbrel umbrel startup[11103]: The TOR_PROXY_PORT variable is not set. Defaulting to a blank string.
Dec 21 07:36:04 umbrel umbrel startup[11103]: The TOR_PROXY_IP variable is not set. Defaulting to a blank string.
Dec 21 07:36:04 umbrel umbrel startup[11103]: The NGINX_PORT variable is not set. Defaulting to a blank string.
Dec 21 07:36:04 umbrel umbrel startup[11103]: The NGINX_IP variable is not set. Defaulting to a blank string.
Dec 21 07:36:04 umbrel umbrel startup[11103]: The DASHBOARD_IP variable is not set. Defaulting to a blank string.
Dec 21 07:36:04 umbrel umbrel startup[11103]: The UMBREL_AUTH_SECRET variable is not set. Defaulting to a blank string.
Dec 21 07:36:04 umbrel umbrel startup[11103]: The BITCOIN_P2P_PORT variable is not set. Defaulting to a blank string.
Dec 21 07:36:04 umbrel umbrel startup[11103]: The BITCOIN_RPC_PORT variable is not set. Defaulting to a blank string.
Dec 21 07:36:04 umbrel umbrel startup[11103]: The BITCOIN_RPC_USER variable is not set. Defaulting to a blank string.
Dec 21 07:36:04 umbrel umbrel startup[11103]: The BITCOIN_RPC_PASS variable is not set. Defaulting to a blank string.
Dec 21 07:36:04 umbrel umbrel startup[11103]: The BITCOIN_NETWORK variable is not set. Defaulting to a blank string.
Dec 21 07:36:04 umbrel umbrel startup[11103]: The MANAGER_IP variable is not set. Defaulting to a blank string.
Dec 21 07:36:04 umbrel umbrel startup[11103]: The AUTH_PORT variable is not set. Defaulting to a blank string.
Dec 21 07:36:04 umbrel umbrel startup[11103]: The AUTH_IP variable is not set. Defaulting to a blank string.
Dec 21 07:36:04 umbrel umbrel startup[11103]: The NETWORK_IP variable is not set. Defaulting to a blank string.
Dec 21 07:36:04 umbrel umbrel startup[11103]: The Compose file ‘./docker-compose.yml’ is invalid because:
Dec 21 07:36:04 umbrel umbrel startup[11103]: networks.default.ipam.config.subnet is invalid: should use the CIDR format
Dec 21 07:36:04 umbrel umbrel startup[11103]: services.tor_proxy.ports contains an invalid type, it should be a number, or an object
Dec 21 07:36:04 umbrel umbrel startup[11103]: services.auth.ports contains an invalid type, it should be a number, or an object
Dec 21 07:36:04 umbrel umbrel startup[11103]: services.nginx.ports contains an invalid type, it should be a number, or an object
Dec 21 07:36:05 umbrel umbrel startup[11103]: Failed to start containers
Dec 21 07:36:05 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Dec 21 07:36:05 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Dec 21 07:36:05 umbrel systemd[1]: Failed to start Umbrel Startup Service.
External storage service logs
Dec 21 07:28:31 umbrel external storage mounter[474]: Running external storage mount script…
Dec 21 07:28:31 umbrel external storage mounter[474]: Found device “TO Exter nal USB 3.0”
Dec 21 07:28:31 umbrel external storage mounter[474]: Blacklisting USB device IDs against UAS driver…
Dec 21 07:28:32 umbrel external storage mounter[474]: Rebinding USB drivers…
Dec 21 07:28:32 umbrel external storage mounter[474]: Checking USB devices are back…
Dec 21 07:28:32 umbrel external storage mounter[474]: Waiting for USB devices…
Dec 21 07:28:33 umbrel external storage mounter[474]: Waiting for USB devices…
Dec 21 07:28:34 umbrel external storage mounter[474]: Waiting for USB devices…
Dec 21 07:28:35 umbrel external storage mounter[474]: Checking if the device is ext4…
Dec 21 07:28:35 umbrel external storage mounter[474]: Yes, it is ext4
Dec 21 07:28:35 umbrel external storage mounter[474]: Checking filesystem for corruption…
Dec 21 07:28:35 umbrel external storage mounter[474]: e2fsck 1.44.5 (15-Dec-2018)
Dec 21 07:28:36 umbrel external storage mounter[474]: umbrel: clean, 119054/61054976 files, 212910126/244190208 blocks
Dec 21 07:28:36 umbrel external storage mounter[474]: Mounting partition…
Dec 21 07:28:36 umbrel external storage mounter[474]: Checking if device contains an Umbrel install…
Dec 21 07:28:36 umbrel external storage mounter[474]: Yes, it contains an Umbrel install
Dec 21 07:28:36 umbrel external storage mounter[474]: Bind mounting external storage over local Umbrel installation…
Dec 21 07:28:36 umbrel external storage mounter[474]: Bind mounting external storage over local Docker data dir…
Dec 21 07:28:36 umbrel external storage mounter[474]: Bind mounting external storage to /swap
Dec 21 07:28:36 umbrel external storage mounter[474]: Bind mounting SD card root at /sd-card…
Dec 21 07:28:36 umbrel external storage mounter[474]: Checking Umbrel root is now on external storage…
Dec 21 07:28:37 umbrel external storage mounter[474]: Checking /var/lib/docker is now on external storage…
Dec 21 07:28:37 umbrel external storage mounter[474]: Checking /swap is now on external storage…
Dec 21 07:28:37 umbrel external storage mounter[474]: Setting up swapfile
Dec 21 07:28:38 umbrel external storage mounter[474]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Dec 21 07:28:38 umbrel external storage mounter[474]: no label, UUID=9261e5a2-fd72-42af-8e1d-71b11145ab3e
Dec 21 07:28:38 umbrel external storage mounter[474]: Checking SD Card root is bind mounted at /sd-root…
Dec 21 07:28:38 umbrel external storage mounter[474]: Starting external drive mount monitor…
Dec 21 07:28:38 umbrel external storage mounter[474]: Mount script completed successfully!
Dec 21 07:28:38 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Sat 2024-12-21 07:27:55 UTC, end at Sat 2024-12-21 07:36:11 UTC. –
Dec 21 07:28:49 umbrel systemd[1]: Starting External Storage SDcard Updater…
Dec 21 07:28:49 umbrel external storage updater[911]: Checking if SD card Umbrel is newer than external storage…
Dec 21 07:28:49 umbrel external storage updater[911]: No, SD version is not newer, exiting.
Dec 21 07:28:49 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
Tor Proxy logs
==== Result ====
Managed to solve myself - I was trying to flash v0.5.4-patch-1 but I had already upgraded raspberry pi 4 to umbrelOS 1.0 and using that image worked after flashing the new software.
Hi Mark1,
Thanks for the help. This fixed the same error I was having!
