Don't See Nostr App - v0.5.4 Upgraded Node
I see that Nostr is available for Umbrel, but I don’t see it in the revamped app store, even though there is a github page – https://github.com/getumbrel/umbrel-nostr-relay (I tried using the local search in the app store, but no result.)
Is this a cache thing where the app store has to refresh? Why can’t I install it via the app store?
Appreciate any info…
Been 19 days… not a single response?
Is NOSTR being censored somehow? I still can’t see it on my app store.
Any help?
Comon…
I’m so very happy yours works.
I guess I’ll just junk this garbage and get some real hardware/software to run.
In tech support circles, saying “Mine works” is essentially an insult. It means someone had just enough energy to tell you they are working just FINE, but hey, your problem? “Dunno bro, good luck.”
Yeah, this community sucks.
Don’t worry, its in the bin of useful suggestions such as:
“Turn it off and on again”
“Reinstall your OS, then everything else”
“Just update everything, I don’t know what specifically, but just do it all”
“Maybe change houses or apartments”
“Probably your ISP, change that too”
All prime Tier-0/1 customer support desk responses. Its okay, I’m going with something that doesn’t suck, so don’t bother replying.
Did you take a look at the troubleshooting guide at all, and try their recommended solution?
