As most of you probably know, the leaders of the Samourai server have been arrested, and the website has been seized. I assume the authorities are investigating everything thoroughly at the moment.
Is it still safe to use the Samourai server on Umbrel in conjunction with the wallet?
As I understand it from the RoninDojo Blog, using it shouldn’t be a problem:
“After having spoken to lawyers on the subject, there is no reason to believe that running your own node software is illicit, nor is writing the code illicit, and Samourai Wallet (when using your own RoninDojo backend) is STILL the best Bitcoin wallet in the space…”
By the way, there is a Samourai Defense Fund. If anyone would like to support the whole thing, they can do so here: Samourai Defense Fund
