Hi everyone,
I’m considering buying an Umbrel Home (N150). Is it possible to eventually install plain Debian on it if I feel like it? Are the drivers readily available or it’s more of a closed machine? Thanks.
I think you have to opt for a mini PC if you want to install other os! Umbrel home is a machine dedicated to umbrel os!
Yes You can! But you have to open the case of the umbrel home. Inside is a hidden hdmi port that you need for flashing the device with another OS. I did this with Zima OS and it works well!
