Added LibreWolf.
Awesome work! If you’re taking requests, this is something that I personally would like to try as a NextCloud alternative:
https://github.com/opencloud-eu
Hey @paulhall!
Thanks for your suggestion! I’d love to implement it. However, I checked the GitHub repository, and there are still quite a few open issues. It’s probably best to wait for a more stable version. I’ll keep an eye on it and revisit it later. ![]()
Added Restreamer.
Added PicProse.
Added Kokoro.
Could you also consider adding wger?
No problem! I’ll put it on my list. ![]()
Added AnonAddy.
Greetings, could you try adding this tool?
Hey @Dax! Thanks for your suggestion. I’ll put the app on my list. ![]()
Added Donetick.
Thanks Denny!
I just tried the app albeit being “in-progress” and just wanted to report an issue with it:
Pulling images for app denny-wger...
Mar 09 05:24:31 umbrel umbreld[430672]: time="2025-03-09T05:24:31Z" level=warning msg="/opt/umbreld/source/modules/apps/legacy-compat/docker-compose.app_proxy.yml: the attribute `version` is obsolete, it will be ignored, please remove it to avoid potential confusion"
Mar 09 05:24:31 umbrel umbreld[430672]: time="2025-03-09T05:24:31Z" level=warning msg="/opt/umbreld/source/modules/apps/legacy-compat/docker-compose.common.yml: the attribute `version` is obsolete, it will be ignored, please remove it to avoid potential confusion"
Mar 09 05:24:31 umbrel umbreld[430672]: time="2025-03-09T05:24:31Z" level=warning msg="networks.default: external.name is deprecated. Please set name and external: true"
Mar 09 05:24:31 umbrel umbreld[430672]: time="2025-03-09T05:24:31Z" level=warning msg="/home/umbrel/umbrel/app-data/denny-wger/docker-compose.yml: the attribute `version` is obsolete, it will be ignored, please remove it to avoid potential confusion"
Mar 09 05:24:31 umbrel umbreld[430672]: env file /home/umbrel/umbrel/app-data/denny-wger/data/config/prod.env not found: stat /home/umbrel/umbrel/app-data/denny-wger/data/config/prod.env: no such file or directory
Mar 09 05:24:31 umbrel umbreld[873]: [app ] [error] Attempt 2 installing app denny-wger failed. There are 1 retries left.
I suppose the app dir needs to be user agnostic?
Please be patient. ![]()
The app is still in progress, and no changes have been made to Umbrel yet.
Yes of course and apologies. I just wanted to report a potential early issue before it is officially released in your app store. ![]()
Hello,
Would you mind adding this? (If your waiting list isn’t already too full)
is there any guide on how to use it as self-hosted?
See app description: GitHub - anonaddy/docker: AnonAddy Docker image
Is in progress. ![]()
Added Glances.
