Added Crafty Controller. (Suggestion from @GrouxCL)
What speed! Thanks @denny !
It’s getting to be a lot, you should contact Umbrel to boost and refresh their official App Store. And then I saw that you keep them up to date, how do you do with so many apps? ![]()
Denny, you are amazing. I don`t know how you do it. Just wanted to say that you are appreciated. Thank you so much.
I try to keep the apps in my store as up-to-date as possible, but I’m often reliant on users letting me know when an app needs updating. Every now and then, I make pull requests for apps in the official Umbrel App Store, usually for apps I personally use or when users tell me they really want to see them in the store. I’m not a coder; I do this just for fun. ![]()
Thank you so much! ![]()
That really means a lot to me. I’m just trying to do my part and help out where I can. I’m glad it’s appreciated! ![]()
Added Habitica.
Added Luanti.
Added YTPTube.
Added Gopeed.
Great work Denny!
Could you also add Octbot GitHub - Drakkar-Software/OctoBot: Open source crypto trading bot
Hey @renze! Thanks for the suggestion and kind words! ![]()
I use Umbrel precisely because it’s 100% focused on Bitcoin and has nothing to do with cryptocurrencies or trading. Crypto trading and similar apps don’t really align with the philosophy I support. Bitcoin stands for decentralization and financial freedom, and that’s where I want to keep the focus. I hope you understand.
Thanks for your understanding and support! ![]()
A request for Monica, please. First link is site, second link is code, third link is code already dockered-up but for yunohost. Thank you!
“Monica is an open-source web application to organize the interactions with your loved ones. I call it a PRM, or Personal Relationship Management. Think of it as a CRM (a popular tool used by sales teams in the corporate world) for your friends or family.”
Hey @box2321!
Great suggestion! I think Monica is an awesome app, and I’ll implement it in my community app store as soon as possible! ![]()
Added Mumble Server. (Suggestion from @wast)
Added FluidCalendar.
Thanks for adding Monica to your umbrel community app store! I have installed and that went just fine. I tried opening (via TailScale) and I got the following error: “Whoops! Something went wrong. / SQLSTATE[HY000] [1045] Access denied for user ‘monica’@‘X.X.X.X’ (using password: YES) (SQL: select * from instances limit 1) / Back to homepage” I have X’d out part of the error message; it wasn’t my TailScale address, if that is any help.
I apologize for the confusion! The issue was that the DB_HOST value in the docker-compose.yml was set to db. After changing it to denny-monica_db_1, the app is now working perfectly with Tailscale.
Please uninstall the app again, and you may need to clear your browser cache as well.
Thank you for your patience! ![]()
I confirm! Uninstalled, re-installed, Monica now working just fine over talescale. Thanks!
