Dennys Umbrel App Store ☂️
Attempting to export either / both SQL and JSON data from Monica on umbrel, I get the not-very helpful error message “Failed.” Do you have any suggestions on how to fix this? Thanks.
You should check out this link. It seems to be a known issue with Monica affecting other users as well. The page contains a few solutions you can try via the terminal. Hopefully, one of them helps!
Added RustDesk Server.
Hi Denny- I have a question but not sure how to direct message you. I run a btc node on The Bitcoin Machine and wonder if you /or you know someone I could consult with to use umbrel and this machine. Thanks ! Caroline cwsory@gmail.com
Added tldraw.
AppFlowy seems like a good addition. It is a notion alternative
Added Twenty.
Hi Denny,
Amazing community App Store !
I just added it, I’m interested with some of your apps
Thanks for this great work !
Philippe
Hi Philippe,
Thank you so much for the kind words! I’m glad to hear you like the Store. I hope you enjoy using the apps - feel free to reach out if you have any questions or need help with anything. :smiling_face:
Thanks again for your support! :muscle:
Added Nomie.
Added Umbrel.
umbrel on umbrel? what’s that for?
A groundbreaking new way to elevate your Umbrel experience by running Umbrel inside Umbrel!
Why?
Because sometimes, innovation happens on a very specific day of the year. :wink:
Added Papermerge.
Added PdfDing.
Added OpenReader WebUI.
Hi Denny, wanted to thank you, your store has been very useful to me. :slight_smile:
Also, was wondering, do you think it would be possible to include Postiz app?
Could you change gopeed’s download path to ${UMBREL_ROOT}/home/Downloads or something similar that shows up in the file explorer so you don’t have to navigate through the application folders? It would be a great help. I’ve managed to do it manually, but every time you update it, it changes (or so I think), so it’s better if you do it.
I’ve adjusted it accordingly. Makes sense! :smiling_face_with_sunglasses:
Hey @Dionisius!
Thank you for the suggestion and the kind words! I’m really glad to hear that the store has been helpful. :smiling_face_with_sunglasses:
I’m currently working on configuring the Postiz app. Unfortunately, it’s not available as a multi-arch image, so I can only integrate it in the amd64 version for now. Additionally, there are quite a few open issues on GitHub related to the Docker image. However, I’m actively working on getting everything up and running and will keep you updated.
Thanks for your patience and understanding! :muscle:
