Hello everything is fine?
I’m having problems connecting my light wallet to the BTCPAY system
I have two servers on AWS
1 - with umbrella installed
2 - with CtcPay Server Installed
Each machine running a system individually.
Both are pointing the IP to my domain
umbrel.mydomain.com.br
btcpay.mydomain.com.br
My domain server already has an SSL, that is, all traffic that enters my domain will be able to use HTTPS
First, I installed BtcPay Server on my ec2
Connect to the server via SSH.
Become superuser:
sudo su - -
Update system packages:
sudo apt update -
Install Docker:
sudo apt install docker.io -
Set environment variables for the BTCPay Server:
export BTCPAY_HOST=btcpay.mydomain.com.br export BTCPAY_PROTOCOL=https export REVERSEPROXY_DEFAULT_HOST="$BTCPAY_HOST" -
Create a directory for the BTCPay Server:
mkdir BTCPayServer -
Start and enable Docker:
sudo systemctl start docker && sudo systemctl enable docker -
Install Docker Compose:
sudo curl -L "https://github.com/docker/compose/releases/download/1.29.2/docker-compose-$(uname -s)-$(uname -m)" -o /usr/local/bin/docker-compose sudo chmod +x /usr/local/bin/docker-compose -
Clone the btcpayserver-docker repository in the created directory:
cd BTCPayServer git clone https://github.com/btcpayserver/btcpayserver-docker cd btcpayserver-docker -
Set additional environment variables required for configuration:
export NBITCOIN_NETWORK="mainnet" export BTCPAYGEN_CRYPTO1="btc" export BTCPAYGEN_ADDITIONAL_FRAGMENTS="opt-save-storage-s" export BTCPAYGEN_REVERSEPROXY="nginx" export BTCPAYGEN_LIGHTNING="lnd" export BTCPAY_ENABLE_SSH=true -
Start the BTCPay Server configuration script:
. ./btcpay-setup.sh -i
These were the commands I used to install the system on my EC2
Then I ran it on another ec2, Umbrel. I installed Node Bitcoin, Node Light and waited for synchronization.
First question!
Umbrel doesn’t load when I put HTTPS in the url, even though my domain allows HTTPS. It only opens with HTTP.
Second question!
When I connect the BTCPAY SERVER with Umbrel, I do the following:
Go to the side menu, access the page > Lightning node then > Connect to a Lightning node
Remember that when installing BTCPAY I chose LND because it is native to Umbrel, right?
The problem I face is:
My Node on Umbrel is only being accessed via HTTP and BTCPAY requires the connection to be https as shown in the image above
type=lnd-rest;server=https://mylnd:8080/;macaroon=abef263adfe...
When I put mylnd (TOR address or any other address, it always starts with numeto and not http)
Where and how can I get this address as required by btcpay?
