I can’t connect bitbox to humbrel with tor. He only managed to connect it in local mode. Any advice??
its actually better to use local from inside your own network otherwise your doing a complicated loop all over the world and then back into your network.
That is slow and sometimes causes issues.
What I find is that if you insist on using tor at home expect slowness at the VERY least.
Tor is ran by volunteers and bandwidth can be limited. Your also going through 6 servers to get from point A to point B.
Its great for hiding your nodes location from other nodes and your ISP.
And It works better outside your home network but what really works better is a VPN.
its faster and just as safe. Use Tailscale or whatever other options you have open to you.
I like wireguard. Some Routers have a good VPN but most are trash.
Thanks, I will work in local mode.
you could also take a look Wie kann ich die Bitbox02 via Sparrow Wallet mit Bitcoin Core verbinden? - Fragen - Blocktrainer Forum , here ![]()
Thank you very much, I will study it.
