I am successfully running Umbrel on my raspberry Pi4 in my local LAN, however, cannot connect either BitBox App or electrum wallet. Under BitBox App the following error is shown:
dial tcp 127.0.0.1:9050: connect: connection refused
Tried to change 127.0.0.1 to LAN address of the Umbrel node but without success.
Any suggestions how to solve this?
Thxs
Do you have Tor source code running on your computer?
TOR is not running on my iMac
It needs to be running. You need to follow all the steps in the connect wallet section for the Bitbox app to properly connect with umbrel.
Umbrel with TOR is running on my raspberry Pi. If I additionally install TOR on my Mac - what I did - I can only reach Umbrel via the remote access address and when following the instructions under wallet section for the Bitbox, the connection to Bitbox cannot be established.
ok, thxs. I tried to install the source code with homebrew but received the following notice:
Aug 19 11:20:52.227 [notice] Tor 0.4.6.7 running on Darwin with Libevent 2.1.12-stable, OpenSSL 1.1.1k, Zlib 1.2.11, Liblzma N/A, Libzstd N/A and Unknown N/A as libc.
Aug 19 11:20:52.227 [notice] Tor can’t help you if you use it wrong! Learn how to be safe at https://www.torproject.org/download/download#warning
Aug 19 11:20:52.227 [notice] Configuration file “/usr/local/etc/tor/torrc” not present, using reasonable defaults.
Aug 19 11:20:52.229 [notice] Opening Socks listener on 127.0.0.1:9050
Aug 19 11:20:52.229 [warn] Could not bind to 127.0.0.1:9050: Address already in use. Is Tor already running?
Aug 19 11:20:52.229 [warn] Failed to parse/validate config: Failed to bind one of the listener ports.
Aug 19 11:20:52.229 [err] Reading config failed–see warnings above.
Don’t know whether I did something wrong during the installation process - I am not an IT expert.
Can you please include your instruction link for installing source code from your first post; it was not working. Or any other suggestions?
