denny
1
Apps that are tunneled with Cloudlare cannot be accessed from the Umbrel dashboard. This can only be done by manually changing the following file:
sudo nano umbrel/app-data/cloudflaredumbrelapp/umbrel-app.yml
path: "https://your.cloudflared.domain"
Is this consistent after an update? Is there a possibility that the Cloudlare app will change this itself?
denny
2
The problem was solved:
It was actually due to the tunneled Nextcloud app. Unfortunately Umbrel doesn’t like https…
