I’m running umbrelOS 1.3 on a x86 PC.
I had to reinstall Fulcrum and the app is stuck now. The app store is stuck with the “Uninstalling…” message.
I logged with SSH and tried umbreld client apps.uninstall.mutate --appId fulcrum, if failed with this message:
TRPCClientError: Command failed with exit code 1: /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/app-script stop fulcrum
at TRPCClientError.from (file:///usr/local/lib/node_modules/umbreld/node_modules/@trpc/client/dist/TRPCClientError-38f9a32a.mjs:27:20)
at file:///usr/local/lib/node_modules/umbreld/node_modules/@trpc/client/dist/links/httpLink.mjs:35:60
at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
meta: {
response: Response {
[Symbol(realm)]: null,
[Symbol(state)]: [Object],
[Symbol(headers)]: [HeadersList]
responseJSON: { error: [Object] }
shape: {
message: 'Command failed with exit code 1: /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/app-script stop fulcrum',
code: -32603,
data: {
code: 'INTERNAL_SERVER_ERROR',
httpStatus: 500,
stack: 'Error: Command failed with exit code 1: /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/app-script stop fulcrum\n' +
' at makeError (file:///usr/local/lib/node_modules/umbreld/node_modules/execa/lib/error.js:60:11)\n' +
' at handlePromise (file:///usr/local/lib/node_modules/umbreld/node_modules/execa/index.js:124:26)\n' +
' at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n' +
' at async RetryOperation._fn (file:///usr/local/lib/node_modules/umbreld/node_modules/p-retry/index.js:55:13)',
path: 'apps.uninstall',
zodError: null
data: {
httpStatus: 500,
zodError: null
[cause]: undefined
If I try to install it, with umbreld client apps.install.mutate --appId fulcrum, I have another failure:
TRPCClientError: App fulcrum is already installed
meta: {
shape: {
message: 'App fulcrum is already installed',
code: -32603,
data: {
httpStatus: 500,
stack: 'Error: App fulcrum is already installed\n' +
' at Apps.install (/usr/local/lib/node_modules/umbreld/source/modules/apps/apps.ts:208:44)',
path: 'apps.install',
zodError: null
data: {
httpStatus: 500,
zodError: null
[cause]: undefined
