I’ve been running umbrel on a Raspberry Pi, Ethernet, SSD for a few months now. During this time the SSD would blink blue and wallets connected without issue, but for the past few weeks it blinks red and my wallets fail to connect. The web interface works and the blockchain is up to date.
I can´t find an obvious problem in logs. TOR logs seems strange, but i don´t understand it, sorry. If you get active peers, TOR is normal. Indexing seems to be still running, so guess you won´t get on-line channels until it finishes. SSD seems working normal.
A simple way to see if still indexing is to look if high cpu activity of bitcoind and electrs processes by ssh command ‘top’ in a terminal window.
