Can't access Nextcloud after upgrade
After upgrading to Umbrel 0.4.1 Nextcloud stopped working and showed this message:
Access through untrusted domain
Please contact your administrator. If you are an administrator, edit the “trusted_domains” setting in config/config.php like the example in config.sample.php.
How can I fix this? Thank you in advance!
After update trusted domains config reset to deafault. Follow this guide:
http://community.umbrel.com/t/new-umbrel-4-0-nextcloud-app/2421/4?u=vilas1979
Thank you @Vilas1979, it worked!
