I have set up Umbrel at home and then I bring the Umbrel to my office.
I can loate Umbrel with IP Scanner and type the IP address found on the scanner (because umbrel.local/ did not work)
The browser now shows “Welcome Back” and asks for the password. However, the “Login” buttun is just blinking and never guides me to the dashboard.
I don’t have a solution but a workaround. If you open Umbrel Login in a tor browser by entering umbrel tor address you can login again. The way to get there is:
- ssh into your umbrel node (if you don’t know how to do this, google it)
- enter cd ~/umbrel/tor/data/web , in that directory you will find a file named ‘hostname’
- enter nano hostname
- you can now see tor address of your node, copy it
- exit with ctrl-x
- enter/paste that onion address into a tor browser (if you dont have one get one from here: https://www.torproject.org/download/)
- you should now see umbrel login page
- enter your password and you should be back in admin page
- let me know if it worked
