New installation. Bitcoin node is installed and fully synced. Nothing else is installed.
Tried to install lightning app. Does not install.
Check container logs.
Checking LND status...
[backup-monitor] Starting...
[backup-monitor] Checking channel backup...
(node:31) DeprecationWarning: grpc.load: Use the @grpc/proto-loader module with grpc.loadPackageDefinition instead
(Use `node --trace-deprecation ...` to show where the warning was created)
Listening on port 3006
[backup-monitor] Error: ENOENT: no such file or directory, open '/data/.lnd/data/chain/bitcoin/mainnet/channel.backup'
[backup-monitor] Sleeping...
node:internal/process/promises:279
triggerUncaughtException(err, true /* fromPromise */);
[Error: ENOENT: no such file or directory, open '/data/.lnd/tls.cert'] {
errno: -2,
code: 'ENOENT',
syscall: 'open',
path: '/data/.lnd/tls.cert'
I then created the external paths to fulfil the container-internal /data/.lnd/ and /data/.lnd/data/chain/bitcoin/mainnet/ but the error message continues (presumably because channel.backup and tls.cert do not exist).
Can anyone advise where this has gone wrong and what I should do next?
