Hello, I’m trying to install the Lightning node app but it’s been several days and it doesn’t install
have you installed bitcoin node and let it sync fully?
whats the logs say?
Everything has been running 100% well for a week. How can I see the records?
In what part in particular?
lightning_app_1 is up-to-date
lightning_app_proxy_1 is up-to-date
Starting lightning_tor_1 …
lightning_tor_server_1 is up-to-date
Starting lightning_lnd_1 …
Host is already in use by another container
Starting lightning_lnd_1 … error
ERROR: for lightning_lnd_1 Cannot start service lnd: driver failed programming external connectivity on endpoint lightning_lnd_1 (37c999e48c993ea5f0526eca8078902e33d13fd1ea1c64fb2d129260742544e1): Bind for 0.0.0.0:8080 failed: port is already allocated
Starting lightning_tor_1 … done
ERROR: for lnd Cannot start service lnd: driver failed programming external connectivity on endpoint lightning_lnd_1 (37c999e48c993ea5f0526eca8078902e33d13fd1ea1c64fb2d129260742544e1): Bind for 0.0.0.0:8080 failed: port is already allocated
Got signal: debug
karen is getting triggered!
these thing is so slow to send out emails or Im not getting them.
did you fix it?
