Failed to reach my umbrel.local
additional insights
Blockquote
0.5.3
Flashed OS version
v0.5.3
Raspberry Pi Model
Revision : d03114
Serial : 10000000f6977d01
Firmware
Dec 1 2021 15:01:54
Copyright (c) 2012 Broadcom
Temperature
temp=47.2’C
Throttling
throttled=0x0
Mem: 7.8G 150M 7.2G 16M 447M 7.5G
Swap: 4.1G 0B 4.1G
total: 1.9%
system: 1.9%
tailscale: 0%
nostr-relay: 0%
mempool: 0%
lightning: 0%
invidious: 0%
electrs: 0%
bitcoin: 0%
alby-nostr-wallet-connect: 0%
Memory monitor logs
2019-02-14 10:13:02 Memory monitor running!
2019-02-14 10:13:15 Memory monitor running!
2019-02-14 10:13:30 Memory monitor running!
2019-02-14 10:13:43 Memory monitor running!
2019-02-14 10:13:57 Memory monitor running!
2019-02-14 10:14:14 Memory monitor running!
2019-02-14 10:14:27 Memory monitor running!
2019-02-14 10:14:42 Memory monitor running!
2019-02-14 10:14:55 Memory monitor running!
2019-02-14 10:15:09 Memory monitor running!
/dev/root 29G 29G 0 100% /
/dev/sda1 916G 711G 159G 82% /home/umbrel/umbrel
Startup service logs
Feb 14 10:15:08 umbrel umbrel startup[8929]: ============== UMBREL ================
Feb 14 10:15:08 umbrel umbrel startup[8929]: ======================================
Feb 14 10:15:08 umbrel umbrel startup[8929]: Setting environment variables…
Feb 14 10:15:08 umbrel umbrel startup[8929]: Starting karen…
Feb 14 10:15:08 umbrel umbrel startup[8929]: Starting status monitors…
Feb 14 10:15:08 umbrel umbrel startup[8929]: Starting memory monitor…
Feb 14 10:15:08 umbrel umbrel startup[8929]: Starting backup monitor…
Feb 14 10:15:08 umbrel umbrel startup[8929]: Starting decoy backup trigger…
Feb 14 10:15:08 umbrel umbrel startup[8929]: Starting Docker services…
Feb 14 10:15:11 umbrel umbrel startup[8929]: Starting auth …
Feb 14 10:15:11 umbrel umbrel startup[8929]: Starting dashboard …
Feb 14 10:15:11 umbrel umbrel startup[8929]: Starting tor_proxy …
Feb 14 10:15:11 umbrel umbrel startup[8929]: Starting manager …
Feb 14 10:15:12 umbrel umbrel startup[8929]: Starting manager … error
Feb 14 10:15:12 umbrel umbrel startup[8929]: ERROR: for manager Cannot start service manager: failed to start shim: mkdir /var/lib/containerd/io.containerd.runtime.v2.task/moby/cc4e50cd7e8207f00a287bab728a1142d15d27e123b3bcd9b5b665649f7d2e76: no space left on device: unknown
Feb 14 10:15:12 umbrel umbrel startup[8929]: Starting dashboard … error
Feb 14 10:15:12 umbrel umbrel startup[8929]: ERROR: for dashboard Cannot start service dashboard: failed to start shim: mkdir /var/lib/containerd/io.containerd.runtime.v2.task/moby/e95393428263f8b3feaa906bcd9462f3efc2e935d097af0cb8374ad4596e09bb: no space left on device: unknown
Feb 14 10:15:12 umbrel umbrel startup[8929]: Starting auth … error
Feb 14 10:15:12 umbrel umbrel startup[8929]: ERROR: for auth Cannot start service auth: failed to start shim: mkdir /var/lib/containerd/io.containerd.runtime.v2.task/moby/6ac1a43e3cb2e22b64cc5599c4f05f94178241523fd3f250dd9332c31617bc0f: no space left on device: unknown
Feb 14 10:15:12 umbrel umbrel startup[8929]: Starting tor_proxy … error
Feb 14 10:15:12 umbrel umbrel startup[8929]: ERROR: for tor_proxy Cannot start service tor_proxy: failed to start shim: mkdir /var/lib/containerd/io.containerd.runtime.v2.task/moby/f1d3f5076afccd1c97db69cc2bc201b019fe3e26eacd48a787a793e2bc021925: no space left on device: unknown
Feb 14 10:15:12 umbrel umbrel startup[8929]: Encountered errors while bringing up the project.
Feb 14 10:15:12 umbrel umbrel startup[8929]: Failed to start containers
Feb 14 10:15:12 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Feb 14 10:15:12 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Feb 14 10:15:12 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Blockquote
