Umbrel update 5.0 through Tor
Hello
Before I updated umbrel I could access my node through tor, after update I can still get to Home Screen but when trying to open Bitcoin node app to check my sync percentage as just turned my node on first time yesterday. Now it says security risk?
Any ideas? As before update you could see on Home Screen the Bitcoin block validation, but update you need to click into the Bitcoin app. And it asks for password when I’m not at home? Is it for security reasons?
Thanks in advance
Hey, same issue.
Did you have some updates?
Hello
Do you have 2Fa active?
I turned off my 2fa then set it up again to start and it fixed it.
Hope you get it sorted
