Can’t connect to Mempool App
I don’t have much to go on here really. I just get a standard “can’t connect to server” when trying to open the Mempool app.
I’ve tried uninstalling and reinstalling and rebooting in various orders of operations, no luck so far. Any ideas out there?
Looks like Pi-hole was somehow breaking my ability to get to the Mempool app. Going to try some different ways of resolving the conflict. Any ideas?
Well, it looks like I’ve managed to shake it loose. After I worked out that Pi-Hole was the cause, I recofigured my local DNS back to it’s default. I uninstalled and re-installed Mempool.
After I confirmed it was working in that state, I tried again to configure Pi-Hole as the local DNS on my router, and it looks like things are still working. Not sure what happened the first time, but we’re all good now.
what exactly did you do?
this is the exact issue im having
nevermind I redid my default DNS like you did and app is working now too!
