Issues w/ Mempool and Lightning Terminal
Hi there
Some apps seem to be working OK, but others are giving me issues.
  • I can’t access Mempool at all, and it always says restarting in SSH:
  • Lightning Terminal gives me this issue: image
  • I sometimes see other issues from ThunderHub on the login page, but everything seems to work correctly.
Thoughts?
I am seeing same issue with Lightning Terminal as well, with the addition of “unable to fetch Batch” “Unable to Fetch Leases”
well, I’m glad I’m not the only one.
I think I’ve narrowed my issue down to manager being on the same port as Mempool (3006) instead of 3005, but I haven’t had a chance to figure out how to fix that.
I deleted the app and reinstalled and that seemed to fix it!
Yeah, unfortunately that doesn’t work for me, and Mempool still isn’t working. Lots of issues with my node, and I don’t want to start fresh :frowning:
do you have Pihole. my mempool issue was related to that and the DNS setting
Can you give some more info?
I am also have trouble starting mempool after installing Pihole. Have tried uninstalling and re-installing but mempool will not work.
