bug in clean install
Hi, I’m new to the forum and I’m looking for support.
I’m doing a clean install on a mini pc with 1TB of disk.
When I do the clean install, I log into the system and create the account.
And on the main page it doesn’t show any applications to install.
When I force an update from the terminal, it doesn’t happen and the % doesn’t go from 0.
Is this error common? I tried an alternative installation, on a 120GB disk for data, and the TB for the block and apps
but I’ve had the same problem solved, without being able to install a single app.
