I just installed the latest release on a Pi 4 with 8GB. I have a 2TB SSD. Everything seems to startup properly, but when I try to install ANY app, it says INSTALLING, then quickly changes to NOT RUNNING. The app is not actually installed and is not accessible. Has been running about 3 hours.
Did you try from ssh?
umbreld client apps.install.mutate --appId <app-id>
Seems to have failed
@dmclark442 we just fixed this issue and pushed out 1.0.4 via OTA, you should be able to update from settings, let me know if that works for you!
Will try to flash and start from scratch
sudo mender install https://download.umbrel.com/release/1.0.4/umbrelos-pi.update && sudo reboot
Re-flash to 1.0.4 worked. Bitcoin node installing now.
