Bluetooth in Umbrel Home
How can I use the bluetooth device, which should be implemented in the umbrel home (according to the webpage of the umbrel home). Especially ’d like to use it in Home Assistant.
But I can’t see any settings somewhere and my Home Assistant says, that there is no entity found for bluetooth.
Any help would be very appreciated. Thanks.
Kind regards
Don
Is the community dead? I don’t get any response…
I think they rely on the community too much for awnsers.
But I just installed it so I could see what’s up.
you go to settings then click on Devices and services then click on add integration then scroll down in the popup window and select Bluetooth.
But your Bluetooth has to be Linux compatible for it to show up and the people that make Bluetooth never supported Linux so your results can very even if it detects it.
