Blocked by ORB issue
Hello,
I’ve recently Umbrel OS on my Raspi 4b flawlessly. It works fine with Nextcloud but I have an issue with Penpot. The installation seemed to work fine I I can use the program in general. But the previews penpot is generating for files are frames inside a design file can’t be loaded (see screenshots). The location where penpot is trying to load the assets from is for example:
http://umbrel.local/assets/by-id/a4183187-858e-4cba-b458-3b59bb5a5833
In the inspection I can see them so it saves them but loading is prevented somehow.
Any ideas how I can fix that?
Thanks in advance,
Hoffi
I just realized that its probably related to the missing port in the asset URL which why it has cross origin issues. Any idea how to fix that?
