Bitcoin Node in error Deserialize/Failed to read undo block data
Could you please help me to resolv this problem with bitcoin node
2026-01-02T17:40:18Z [error] Deserialize or I/O error - ReadVarInt(): size too large: iostream error at FlatFilePos(nFile=5101, nPos=15996136) while reading block undo
2026-01-02T17:40:18Z [error] A fatal internal error occurred, see debug.log for details: Failed to read undo block data 00000000000000000000d709037a9623724d9fccb4de2001b26860651d6768d7 from disk
Error: A fatal internal error occurred, see debug.log for details: Failed to read undo block data 00000000000000000000d709037a9623724d9fccb4de2001b26860651d6768d7 from disk
I explored some topic and did
sudo umount /dev/sda3
=> target is busy
sudo lsof /dev/sda3 gives a lot of lines although bitcoin node is stopped and electrs and bitaxe sentry and public pool and mempool and tailscale.
I can not kill all residual processes handly !
How to repare /dev/sda3, that i tought it is bad , in an umbrel mode permitting the repare process ?
or to repare the bitcoin node with option chainstate ?
I thought that /dev/sda3 was corrupted due to
Free Blocks count wrong
Free inodes count wrong
But is is a false problem (I recreated a new VM UmbrelOS and i had the same warnings)
If you suspect a corrupt, the only way to check filesystem (during boot) is to :
modify /etc/fstab
sudo nano /etc/fstab
modify line / and at the end of line 1 0 to 1 1
modify line /data and at the end of line the 0 0 to 0 2
CTRL-O to write on disk the changes
ENTER
CRTL-X to exit
cat /etc/fstab to verify the changes
To correct the bitcoin node :
stop the bitcoin node
sudo nano /home/umbrel/umbrel/app-data/bitcoin/data/bitcoin/bitcoin.conf
add the line
reindex-chainstate=1
CTRL-O ENTER CTRL-X
to write and exit
cat /home/umbrel/umbrel/app-data/bitcoin/data/bitcoin/bitcoin.conf
to verify
restart bitcoin node
Next time (after the reindexing is finished) , comment with a # the line reindex-chainstate=1 to deactivate it.
