Hello aa,
I’ve been looking at the forum and I can’t find a solution to my problem.
My dashboard works fine but when I enter the Bitcoin Node app it permanently appears in starting.
I look at the logs and I don’t find any errors or problems.
I flashed the MicroSD, I have also deleted the peers.dat file and the setting.json etc. in the terminal. and I still have the same problem.
Any solution? I’m desperate.
Thank you so much
              Hi @boomhashing,
Sure thing. So we can troubleshoot this further, we’ll need to generate some logs from your Umbrel- could you please enter the settings dashboard on your Umbrel, and press ‘START’ under troubleshooting.
You can share the output here with https://pastebin.com/, and we’ll see what the issue is.
              Ok nothing stands out from the logs.
Could you please try running the following
sudo ~/umbrel/scripts/app restart bitcoin
Give it 5-minutes, and if the issue is still the same we will try to log it with the following
~/umbrel/scripts/app compose bitcoin logs --tail 400
Which you can share with pastebin.com again
