Bitcoin Node and Knots
Hello! I’m running a Bitcoin full node as Bitcoin Node and I have a question. If I install Bitcoin Knots in this state, will the capacity of the entire node be added? Or will it be shared with the Bitcoin Node’s block files? Or is there something I need to set up separately?
The capacity of the node won’t be automatically added to Bitcoin Knots. Bitcoin Knots is a full Bitcoin node as well, but it operates separately from the Bitcoin Node, even if both are on the same system.
It appears that both Bitcoin Node and Knots store separate blockchain files if that is what you are asking.
Im currently testing Moving the blocks and chainstate folders to the Knots directory. So far it seems to be working…
