I just installed. v.26 Bitcoin core is not syncing. It intially starts and just stops at blockchain size = 293 bytes. Not sure why. I don’t have ufw on my linux box, so it should be clear sailing. I’ll let it sit for a day or two and see if it starts syncing. So, it seems I have some kind of Linux docker issue? Anyone know what it might be?
System Info: Debian XFCE, ip of umbrel.local = 10.0.2.0 . Running Bitcoin core 25.0 raw download, outside of Docker, works fine.
**Update: I got to 3% synced and 110MB It keeps stopping. I do see some TOR errors in the Umbrel logs. I suspect it has something to do with that. I’ll look around for other forum posts about that. 6 hours later I got a little more up to 4.34% I don’t know why it just goes a little and then stops for a long time. **
tor_proxy | Feb 29 17:09:38.000 [notice] Failed to find node for hop #1 of our path. Discarding this circuit.
tor_proxy | Feb 29 17:09:38.000 [notice] Our circuit 0 (id: 80) died due to an invalid selected path, purpose Hidden service: Pre-built vanguard circuit. This may be a torrc configuration issue, or a bug.
tor_proxy | Feb 29 17:12:12.000 [notice] Failed to find node for hop #1 of our path.
I wonder if this is it?
…Tor by default doesn’t bind to all interfaces (as in
0.0.0.0) which doesn’t play nicely with Docker.This can be fixed by adding
SocksPort 0.0.0.0:9050to the/etc/tor/torrc.
I’ll investigate the contents of /etc/tor/torrc if the Umbrel containers will allow me to look inside. Is there a “known issue” with Umbrel on fresh installs of Debian? I suspect it’s a problem with binding to the net interface.
I will try installing just a regular Ubuntu on my device and try it that way. Maybe there is just something wierd about my Debian installer. If that works, I will reply here.
