Bitcoin application stays in "starting"
I recently transferred the blockchain from one hd to another, I was switching, everything working normally on the 1st hd, I only copied the folder in "/umbrel/app-data/bitcoin/data/bitcoin), after a few hours of copying, I start the umbrel, but the bitcoin application doesn’t work, I’ve read some topics here in the community, I did the examples of removing the “peers.dat” and deleting the “settings.json” and creating a new settings.json with this code: {
But nothing worked, I also put “reindex=1” in the file: /umbrel/app-data/bitcoin/data/bitcoin/bitcoin.conf, also nothing.
Logs file debug.log:
/umbrel/app-data/bitcoin/data/bitcoin# tail -f debug.log
2023-07-09T16:22:06Z opencon thread exit
2023-07-09T16:22:06Z Shutdown: In progress…
2023-07-09T16:22:06Z msghand thread exit
2023-07-09T16:22:06Z net thread exit
2023-07-09T16:22:07Z DumpAnchors: Flush 2 outbound block-relay-only peer addresses to anchors.dat started
2023-07-09T16:22:07Z DumpAnchors: Flush 2 outbound block-relay-only peer addresses to anchors.dat completed (0.02s)
2023-07-09T16:22:07Z scheduler thread exit
2023-07-09T16:22:07Z Writing 0 unbroadcast transactions to disk.
2023-07-09T16:22:07Z Dumped mempool: 0.0602512s to copy, 0.289535s to dump
2023-07-09T16:26:28Z Shutdown: done
^C
Reindex will start over reindexing ftom the start. You shouldnt have to do that if ig was working on the ither machine.
Copy the chainstate and blocks folder.
How are you doing it?
You probably have to set permissions.
Give some details
