Bitcoin App Proxy stuck always `Starting...`
Strange one.
Bitcoind container is up and running, so is bitcoin_app_proxy on port 2100.
Screenshot
Blockchain is fully synced, mempool explorer works.
However cannot get a response from the Bitcoin app proxy on umbrel.local:2100 , which results in dashboard constantly showing the App as Starting...
Screenshot
Log for the app proxy shows:
Error wating for port: "connect EHOSTUNREACH 10.21.22.2:3005" Retrying...
Any ideas?
I have the same situation. I hope somebody answer.
Same problem here.
I just upgraded my server from lubuntu 22.10 to 23.04, restarted and have the same problem. bitcoin core and Electrs server “starting”, and I get ERR_CONNECTION_REFUSED when connecting to http://umbrel.local:2100/
Lightning node is working, so apparently bitcoin is being synced?
My CPU is stuck at 100% since I upgraded, and bitcoind is the most used process…
Did anyone solve this? Should I delete peers.dat?
Thanks for any help.
