Apps stuck on “starting…”
Error wating for port: “The address ‘App_web_1’ cannot be found”
Here is the log for one app as an example:
ride-the-lightning
ride-the-lightning-app_proxy-1 | Error wating for port: “The address ‘ride-the-lightning_web_1’ cannot be found”
ride-the-lightning-app_proxy-1 | Retrying…
ride-the-lightning-web-1 | [9/29/2023, 1:11:00 PM] INFO: RTL => Server is up and running, please open the UI at http://localhost:3001 or your proxy configured url.
ride-the-lightning-boltz-1 | INFO : 2023/09/29 13:11:04 Recovering pending Reverse Swaps
ride-the-lightning-boltz-1 | WARN : 2023/09/29 13:11:04 Could not find TLS certificate or key
ride-the-lightning-boltz-1 | INFO : 2023/09/29 13:11:04 Generating new TLS certificate and key
ride-the-lightning-boltz-1 | INFO : 2023/09/29 13:11:04 Connected to LND block epoch stream
ride-the-lightning-boltz-1 | INFO : 2023/09/29 13:11:04 Loaded TLS certificate and key
ride-the-lightning-boltz-1 | INFO : 2023/09/29 13:11:04 Enabling Macaroon authentication
ride-the-lightning-boltz-1 | WARN : 2023/09/29 13:11:04 Could not find Macaroons
ride-the-lightning-boltz-1 | INFO : 2023/09/29 13:11:04 Generating new Macaroons
ride-the-lightning-boltz-1 | INFO : 2023/09/29 13:11:04 Starting REST server on: 0.0.0.0:9003
ride-the-lightning-boltz-1 | INFO : 2023/09/29 13:11:04 Starting RPC server on: 127.0.0.1:9002
I have seen a few entries like this and tried all but no luck.
This started after a maintenance upgrade to the OS Debian 11 to Debian 12
Any help and ideas would be great.
Followed this guide
Step by step installation guide of Umbrel on Linux Ubuntu 237 - by CryptoGarage
NOTE: when you install docker and docker-compose requisites on DebianOS, be aware to choose installation files FOR DEBIAN and not for Ubuntu.
And all apps came up all OK
