So I managed to install Bisq on Umbrel but Im struggling to make it work because Tor.
Bisq embedded Tor doesn’t seem to work and can’t make it connect to Umbrel’s.
Any suggestions?
Is there a control.authcookie file on Umbrel?
I have the same problem but I installed Bisq for desktop on a Mac. Is it possible to install Bisq directly from the Umbrel App Store?
You likely need to enable bloom filters.
I would suggest reviewing this guide here: How To Connect Bisq To Umbrel & Hugely Improve Your Privacy (2023) - Athena Alpha
