Bash-installed scripts on 1.2.1, can't upgrade to 1.2.2
I bash-installed some codes like Git and fan-speed control scripts on 1.2.1, in a SSH way.
Now that 1.2.2 comes out I can’t upgrade it, it waits like 30min and stays the same version.
Hardware is RP4, 2 of them, reason behind I’m certain it’s because of the scripts is that another Pi without any extra scripts works fine by one-click upgrade.
Any help?
I’m having the same issue. Have you found a workaround?
not for the moment.
now we have an awkward situation- we either keep 1.2.1 forever or
do the upgrade by manually flashing the SD with 1.2.2 then reinstall the scripts again, which I’m not sure if it’s safe for existing node and channels.
what’s on your mind?
please can someone help? now that 1.2.3 has come out. I’m beginning to FOMO. Can I just flash the SD offline with the 1.2.3 without impacting the Node and Channels inside?
