I recently added some funds to my Specter wallet a la the Umbrel app. However, the dashboard is not updating with my numbers. From the below, it seems that if I use the Specter Wallet app on Umbrel, that it should automatically update.
That doesn’t seem to be the case though. Let me know what I should look into.
NO. Specter app is NOT using your Umbrel node onchain wallet.
Specter app is using only the node as “blocks provider”, you start and create your own onchain wallets, or connect hardware wallets to it.
So Specter will never show your umbrel bitcoin wallet balance. Be careful where are you sending funds.
If you want a node management app for your umbrel funds, use Thunderhub, RTL, Zeus, Zap
