Autofix Docker Failure when updating from .5.0 to 5.1
I have had a look in the troubleshooting logs and I’m getting this error:
Failed to remove image for service tor_server: 409 Client Error for http+docker://localhost/v1.41/images/lncm/tor:0.4.7.7%40sha256:?force=False&noprune=False: Conflict (“conflict: unable to remove repository reference “lncm/tor:0.4.7.7@sha256:” (must force) - container 63e is using its referenced image 6be”)
Any ideas on how I can go about resolving this so I can update to 5.1? Is it OK to remove one of these containers (with force) or is it going to potentially kill the node?
If I’m not mistaken that is a shared package between docker containers.
It doesn’t get deleted because its shared.
what specific issue are you having?
It keeps prompting me to update to 5.1, even though I have tried a few times now. Interestingly enough in the troubleshooting logs it says the following:
=============== UPDATE ================
=========== Stage: Success ============
Removing backup
Successfully installed Umbrel v0.5.1
== End Update Script 03-run.sh ==
So its like I have updated but it keeps prompting me to install 5.1. The start of the troubleshooting log has the following version:
0.5.0
