Apps not starting after upgrade to 1.0
Since I’ve upgraded most of the installed apps are stuck in “Not running” state.
The only apps that started are pihole and WatchYourLAN.
Some apps that do not start:
  • Jellyfin
  • Sonarr
  • Lidarr
  • Transmission
I’m unable to find any logs to see why they don’t start.
Happy to report that I’ve just tried this and it worked!
You shouldn’t assume your average user knows how to use the terminal. I attempted to find theHow to SSH into umbrelOS on Umbrel Home or Rasberry Pi instructions to no avail.
How about a link?
How to SSH into umbrelOS on Umbrel Home or Rasberry Pi instructions work for me. Open a separate post if you’re having SSH connectivity issues.
Wish I would have seen this post before yesterday. Just wiped the whole Umbrel and storage drive and am now re-syncing.
I thought 1.1 would have solved the issue in the upgrade, but it sill persisted. Hopefully others with the same issue will see this post, as this would have probably solved it for me. Happy halving day!
SSH umbrel@umbrel.local
