Failure out of the blue
Has run smoothly more than a year. Now stopped because “Failed to start containers”. Any hint?
anything in the logs or does it not get that far?
Hi. Besides the umbrel logo, only options are restart and shutdown.
How to access logs?
Give this a try :slight_smile:
Always on top of it. Thanks.
I caught your electrs alternative on github. May give it a try.
Thank you very much.
Got this error msg now in terminal: Failed to stop docker.service. Unit docker.service not loaded
Hi. Thanks a lot for your support. Have tried a lot now and realized that I have to upgrade my ssd soon anyways. Have stopped chasing error messages, will buy the new ssd and set up the system from scratch. Again, thank you. Great support.
