All app "Starting"... but not starting!
Recently restarted the node ane the apps now are locked in a starting status.
tried to restart the node multiple times without success.
Any way I can troubleshoot?
Here is the log in case anyone could help: U_logs - Pastebin.com
Check that your sd card where you put the image of umbrel is still ok.
Mine died with similar simptoms. Now i bought an sd card with the app2 rating. Hope this one will be running longer.
