Alby Hub connection to Alby errors
Is anyone else having problems with Alby node? I have an account with Alby but more often than not I get this message. I mean like most of the time:
  • Alby Services: APIs outage (INVESTIGATING)
  • Could not connect to relay: wss://relay.getalby.com/v1
I also notice that after restarting Alby App sometimes it will connect but after awhile I get the red dot again.. and again. Anyone have a fix for this other than just don’t connect a node with Alby lightening node services? I’m not going to fund a channel if it’s down most of the time. How do you guys handle this? Just eliminate Alby’s website services all together and do your own node? I’m new, they make it simple but it seems they are undependable. Thanks.
