Thanks in advance. I have been a longtime user of Umbrel on a Rpie, but I have no idea what commands to run after I have run the single line provided on the homepage to install Umbrel on linux.
There is nothing else that needs to be run, when the script completes it should display the address you can access your Umbrel at.
You just type that address into your internet browser and off you go!
Thanks. For some reason I have yet to the script to complete. I’ll create try it on a fresh machine. I think this time I will try a simple debian distro vs. ubuntu Ubuntu 20.04.5 LTS.
Thanks for the support…
Ubuntu 20.04 works pretty well by chance did you do an update and upgrade with
sudo apt upgrade && apt upgrade -y
Before installing?
Also are you using a user account other than root that has sudo privileges?
