I can’t access an umbrella, I’ve done everything. umbrel.local, umbrel/, by IP, and does not access.
It would be very helpful if you could provide as much information as possible about your context.
Type of hardware you use.
How does your umbrella connect to the internet?
Has something happened between the time you were able to access it and now you can’t?
Any detail, no matter how small, will help find a solution to your problem.
I use Raspberry 5, I connect via cable, I never got access to it through the browser, I did a network test and I can’t ping it, but using the cable directly on the home screen it shows me the IP.
You say:
I don’t understand this. Can you explain it better, please?
On the other hand you mention:
So, you have just installed umbrelos and you have never been able to access it even to configure a username and password… is that so?
If so, it is best to start from scratch because something went wrong with the installation.
Since I don’t have all the data about your context, I will assume that you have an SSD connected via USB to your RPI5.
I would connect the SSD to my computer, format it and install everything from scratch.
As described in the guide recommended by umbrelos: Install umbrelOS on a Raspberry Pi 5 · getumbrel/umbrel Wiki · GitHub
I had already done what you reported and it hadn’t worked. But I solved it, changing the modem worked. Thanks
