I set up my node on one laptop that I use for day to day uses. I have a separate laptop I’d like to use for only my node and bitcoin transactions. What is the best/ easiest way to access my node from my new laptop? Thanks.
In theory you should be able to access it via umbrel-2.local… If not just use the IP address
