I accidentally cut the power to my Raspberry Pi and after restart I can no longer access Umbrel via umbrel.local. I get “502 Bad Gateway nginx/1.22.1” error.
The umbrel IP address gives me the same error (is a fixed IP address).
I am able to SSH into Umbrel (via Terminal on Mac) and from there I tried restarting NGINX but that did not resolve the gateway error.
I’m stuck
What should I do?
See my debug log below…
0.5.4
total used free shared buff/cache availableMem: 8.2G 439M 7.2G 1.2M 647M 7.7G
Swap: 4.3G 0B 4.3G
total: 5.4%
system: 5.4%
Memory monitor logs
2024-05-21 17:54:18 Memory monitor running!
2024-06-29 16:01:47 Memory monitor running!
2024-07-09 02:46:00 Memory monitor running!
2024-07-27 22:31:32 Memory monitor running!
2024-08-19 00:12:28 Memory monitor running!
2024-09-25 19:31:38 Memory monitor running!
2024-10-17 20:46:42 Memory monitor running!
2024-10-17 23:20:45 Memory monitor running!
2024-10-31 17:51:05 Warning memory usage at 91%
2024-11-20 22:46:14 Memory monitor running!
overlay 48G 4.0G 42G 9% /
/dev/sda1 1.8T 889G 852G 52% /home/umbrel/umbrel
Karen logs
Removing thunderhub_tor_server_1 …
Removing thunderhub_app_proxy_1 …
Removing thunderhub_app_proxy_1 … done
Removing thunderhub_tor_server_1 … done
Removing thunderhub_web_1 … done
Going to remove thunderhub_web_1, thunderhub_tor_server_1, thunderhub_app_proxy_1
Stopping lndg_web_1 … done
Removing lndg_web_1 …
Removing lndg_tor_server_1 …
Removing lndg_app_proxy_1 …
Removing lndg_tor_server_1 … done
Removing lndg_app_proxy_1 … done
Removing lndg_web_1 … done
Going to remove lndg_web_1, lndg_tor_server_1, lndg_app_proxy_1
Stopping lightning-shell_web_1 … done
Removing lightning-shell_web_1 …
Removing lightning-shell_app_proxy_1 …
Removing lightning-shell_tor_server_1 …
Removing lightning-shell_web_1 … done
Removing lightning-shell_tor_server_1 … done
Removing lightning-shell_app_proxy_1 … done
Going to remove lightning-shell_web_1, lightning-shell_app_proxy_1, lightning-shell_tor_server_1
Stopping Docker services…
Stopping nginx …
Stopping tor_server …
Stopping manager …
Stopping tor_proxy …
Stopping dashboard …
Stopping auth …
Stopping tor_server … done
Stopping nginx … done
Stopping tor_proxy … done
Stopping manager … done
Stopping dashboard … done
Stopping auth … done
Removing nginx …
Removing tor_server …
Removing manager …
Removing tor_proxy …
Removing dashboard …
Removing auth …
Removing dashboard … done
Removing nginx … done
Removing auth … done
Removing tor_server … done
Removing tor_proxy … done
Removing manager … done
Docker containers
permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get “http://%2Fvar%2Frun%2Fdocker.sock/v1.44/containers/json”: dial unix /var/run/docker.sock: connect: permission denied
Umbrel logs
/home/umbrel/umbrel/scripts/debug: line 131: docker-compose: command not found
Tor Proxy logs
/home/umbrel/umbrel/scripts/debug: line 137: docker-compose: command not found
This script requires “docker-compose” to be installed
==== Result ====
