2 bitcoin node apps on dashboard?
I am setting up my node and it’s syncing the block chain. I had a power failure and when my node came back up my Umbrel dash showed two bitcoin node apps. If I try to stop one they both stop. I am not sure how to remove one, Thoughts?
I haven’t seen this before, but what happens if you uninstall one of the Bitcoin Node apps? Do both disappear, if so can it then be reinstalled?
Not sure if uninstalling will remove the existing blockchain files which you may want to keep. If you want to keep, then you could probably to rename the blockchain folder while uninstalling just in case.
