the install went OK… started up the BitCoin and LightNing apps… the BitCoin app just sits there - you don’t see blocks updating… I think the node is probably functioning OK - I see the network light on the Raspberry Pi, and the hard drive enclosure lights flashing… And the MemPool app reflects what I see on the BitCoin app - it isn’t showing any movement of the blocks…
turns out the BitCoinNode app might have been updating after the upgrade, not sure… but an update was available for BitCoinNode today, so installed it - and now, FOR SURE, it is working… everything appears to be working… one pretty wayKEWL thing about the upgrade is that even if the login screen times out, the apps that are opened seem to continue to run (BitCoin and LightNing apps)… so that is a positive (in my opinion)…
