I can enter umbrel but I have to click enter twice to type password. It immediately goes to Login incorrect as soon as I type b
Type “b”? Would you explain more?
b for password bitcoin
I try to type in bitcoin but as soon as I get the letter b in it automatically goes to login incorrect
‘b’ first letter of password.
Are you using 2FA? On my node, it only asks me for the password.
no this is the initial login.
No on 2FA
Oh my goodness… and you’ve spent two weeks like this?
Have you seen what it says at the top?
Your umbrel is now accessible at…
Just open a browser and go to umbrel.home
Yep, just found that and logged in. Thanks!
