Withdraw transaction stuck for 2 months. Please help!
2 months ago I withdrew SATs from the Umbrel Bitcoin Wallet.
The transaction appears and disappears in mempool.
I know that I put a small fee.
Transaction stuck for 2 months how to fix the situation?
i would suggest to increase fee if possible
The problem is, How can I increase fee for old transaction from umbrel?
In Lightening shell app trying
bitcoin-cli bumpfee <txid>
Receiving error:
error message:
No wallet is loaded. Load a wallet using loadwallet or create a new one with createwallet. (Note: A default wallet is no longer automatically created)
After sshing into your node, try with this command instead. Hopefully that helps!
sudo ~/umbrel/scripts/app compose bitcoin exec bitcoind bitcoin-cli bumpfee
Check the transaction at mempool.
If you can see RBF near “Features”, you can bump the fee by ssh-ing into your node using a command like this:
~/umbrel/scripts/app compose lightning exec lnd lncli wallet bumpfee 8ae8ae07cf8e38b53a01e93b05210b493b6c84547c651a69857651dd8db5514a:0 --sat_per_vbyte 10
You can turn on RBF under the advanced settings of Bitcoin Node app (Replace-By-Fee (RBF) for All Transactions).
If RBF was not enabled when the tx has been initiated, all you can do is waiting.
Please note if a lightning channel opening transaction takes longer then 2 weeks, then that channel will never be broadcasted, and you will have to force close it (after it finally gets confirmed) in order to get your sats back.
Trying
lncli wallet bumpfee --conf_target 1 tx_id:0
Recieving error:
[lncli] rpc error: code = Unknown desc = the passed output does not belong to the wallet
I am not closing channel, - trying withdraw to external wallet
I assume for the lncli attempt you used the actual tx_id and not ‘0’?
I tried
just tx_id, then tx_id:0, tx_id:1
Without txid:index
gives me error: [lncli] outpoint should be of the form txid:index
You’ll need to use the tx_id that was linked when you were looking at mempool.space
I used this
Yes you need to use that transaction ID in the script below instead of 0 or 1
~/umbrel/scripts/app compose lightning exec lnd lncli wallet bumpfee <tx_id>:0 --sat_per_vbyte 10
this error occured to me as well, but later i managed to run it without any error message
I’m having the same problem. How did you manage to fix it?
It resolved itself after four-five months.
