Let’s get some more details. Some commands didn’t run.
Driver Status: Run lspci -knn | grep -i net -A3 and share the output to confirm if the iwlwifi driver is loaded.
- Key Line to Look For: Kernel driver in use: iwlwifi. If this is missing, the driver isn’t loaded, which would explain why no Wi-Fi interface is detected (as seen with the iwconfig: command not found issue, which we’ll address next).
- The -A3 in grep -i net -A3 ensures we see the three lines after the match, which include the driver information.
Firmware Errors: Run sudo dmesg | grep iwlwifi and share any errors, especially about firmware (e.g., “failed to load iwlwifi-cc-a0-*.ucode”).
Wi-Fi Interface: Run iwconfig and then run iw dev and share the output to see if a wlan0 interface is present.
You’ll need to install it first:
run sudo apt update
run sudo apt install wireless-tools
sudo apt install iw
Share what you find from the above… and let’s see what we need to do as per below>>>>
*////// If you want to read ahead
Step 1: Recap of the Goal
The Intel CNVi Wi-Fi module (likely an AX101, AX201, or AX211) uses the iwlwifi driver in Linux. The kernel version (6.1.0-31-amd64) is recent enough to support this hardware, but we need to ensure:
- The iwlwifi driver is loaded.
- The correct firmware is installed.
- The driver is properly configured for the CNVi module.
Your issue (“Wi-Fi is not supported on this device”) suggests the driver or firmware isn’t working correctly, or Umbrel’s network management isn’t detecting the Wi-Fi interface.
Step 2: Interpret the Diagnostic Outputs
Once you provides the outputs, we’ll look for the following:
- From lspci -knn | grep -i net -A3:
- Key Line: Kernel driver in use: iwlwifi.
- If present, the driver is loaded, and we can focus on firmware or configuration.
- If missing, the driver isn’t loaded, and we need to load it manually or investigate why it’s not loading.
- Device ID: The numeric ID (e.g., [8086:54f0]) will help identify the exact CNVi model (AX101, AX201, or AX211), which determines the firmware needed.
- From sudo dmesg | grep -i iwlwifi:
- Firmware Errors: Look for errors like Direct firmware load for iwlwifi-cc-a0-*.ucode failed with error -2, which indicate missing firmware.
- Driver Errors: Errors like Failed to start INIT ucode: -110 suggest a driver or firmware mismatch.
- From iwconfig or iw dev:
- If a wlan0 interface is present, the driver and firmware are loaded, and the issue is with Umbrel’s network configuration.
- If no interface is present, the driver isn’t working, likely due to missing firmware or a driver issue.
Step 3: Get the Right Drivers and Firmware
The iwlwifi driver is already part of the Linux kernel (since your kernel is 6.1, it’s included), so “getting the right drivers” primarily means ensuring the driver is loaded and the correct firmware is installed. Here’s how to do that based on the diagnostic outcomes:
Scenario 1: Driver Not Loaded (lspci Shows No Kernel driver in use: iwlwifi)
If the lspci output doesn’t show the iwlwifi driver in use, the driver isn’t loaded.
- Manually Load the Driver:
sudo modprobe iwlwifi
This attempts to load the iwlwifi driver module.
2. Check for Errors: After running modprobe, check the logs:
- If it loads successfully, you’ll see messages like iwlwifi 0000:00:14.3: loaded firmware version …
- If it fails, you’ll see errors (e.g., firmware missing or hardware initialization failure).
- Ensure the Driver Module Is Available: The iwlwifi driver should be built into the 6.1 kernel, but confirm it’s available:
ls /lib/modules/$(uname -r)/kernel/drivers/net/wireless/intel/iwlwifi
You should see files like iwlwifi.ko. If it’s missing, the kernel might not have been compiled with iwlwifi support (unlikely, but possible on a custom Umbrel kernel). In that case, you’d need to install a new kernel with iwlwifi support (more on this later).
Scenario 2: Driver Loads but Fails Due to Missing Firmware (dmesg Shows Firmware Errors)
If the driver is loaded (or loads after modprobe) but dmesg shows firmware errors like Direct firmware load for iwlwifi-cc-a0-*.ucode failed, the firmware is missing or incompatible.
- Identify the Required Firmware: The firmware file depends on the CNVi model, which we can infer from the lspci device ID or dmesg error:
- AX101: Needs iwlwifi-cc-a0-*.ucode (e.g., iwlwifi-cc-a0-59.ucode).
- AX201: Needs iwlwifi-so-a0-*.ucode (e.g., iwlwifi-so-a0-hr-b0-64.ucode).
- AX211: Needs iwlwifi-ty-a0-*.ucode (e.g., iwlwifi-ty-a0-gf-a0-66.ucode).The dmesg output will specify the exact file it’s looking for (e.g., iwlwifi-cc-a0-59.ucode).
- Check if Firmware Is Present: You already ran sudo apt install linux-firmware, but verify the files:
ls /lib/firmware/iwlwifi*
Look for the file mentioned in the dmesg error. If it’s missing, proceed to the next step.
3. Install the Firmware: If the firmware is missing, download it from the Linux firmware repository:
sudo mkdir -p /lib/firmware
For example, if dmesg says it needs iwlwifi-cc-a0-59.ucode (common for AX101):
sudo wget -P /lib/firmware https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/plain/iwlwifi-cc-a0-59.ucode
Or for AX201 (iwlwifi-so-a0-hr-b0-64.ucode):
sudo wget -P /lib/firmware https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/plain/iwlwifi-so-a0-hr-b0-64.ucode
You can adjust the URL based on the exact file needed.
4. Reload the Driver: After adding the firmware, reload the driver:
sudo modprobe -r iwlwifi sudo modprobe iwlwifi
Check dmesg again to confirm the firmware loaded:
Scenario 3: Driver and Firmware Load, but No Wi-Fi Interface (iwconfig or iw dev Shows No wlan0)
If the driver is loaded and firmware is present, but no Wi-Fi interface appears, there might be a configuration issue with the iwlwifi driver.
- Check for CNVi-Specific Issues: CNVi modules sometimes require specific driver options. For example, Wi-Fi 6 (802.11ax) can cause issues on some systems:
sudo nano /etc/modprobe.d/iwlwifi.conf
Add:
options iwlwifi disable_11ax=1
Save, then reload the driver:
- Check for Hardware Initialization Errors: Look at dmesg for errors like Failed to start INIT ucode: -110, which indicate the driver couldn’t initialize the hardware. This might require a kernel update or a different firmware version.
Scenario 4: Driver, Firmware, and Interface Work, but Umbrel Doesn’t Detect Wi-Fi
If a wlan0 interface appears in iwconfig or iw dev, the driver and firmware are working, and the issue is with Umbrel’s network management.
- Manually Connect to Wi-Fi: Use nmcli to connect:
nmcli device wifi list nmcli device wifi connect YOUR_SSID password YOUR_PASSWORD
If nmcli isn’t available, install it:
sudo apt install network-manager
- Investigate Umbrel’s Configuration: Look for Umbrel’s network configuration files:
find /etc -name "*network*" find /home/umbrel -name "*network*"
If Umbrel is disabling Wi-Fi, you might need to modify its configuration or reinstall Umbrel on a working Ubuntu base.
Scenario 5: Driver Not Available in Kernel (Unlikely)
If the iwlwifi driver isn’t available in the kernel (checked with ls /lib/modules/$(uname -r)/kernel/drivers/net/wireless/intel/iwlwifi), you’d need to install a new kernel with iwlwifi support. This is unlikely since kernel 6.1 includes iwlwifi, but if needed:
- Install a newer kernel (e.g., 6.5) using the Ubuntu mainline kernel PPA:
sudo apt install software-properties-common sudo add-apt-repository ppa:cappelikan/ppa sudo apt update sudo apt install mainline sudo mainline install 6.5
- Reboot and check the new kernel:
uname -r
Step 4: Summary of How to Get the Right Drivers
- Driver: The iwlwifi driver is already in the 6.1 kernel. Ensure it’s loaded with sudo modprobe iwlwifi. If it’s missing (very unlikely), install a newer kernel.
- Firmware: Download the specific firmware file needed (e.g., iwlwifi-cc-a0-59.ucode for AX101) from the Linux firmware repository, place it in /lib/firmware, and reload the driver.
- Configuration: Adjust driver options (e.g., disable_11ax=1) if needed to resolve CNVi-specific issues.
- Umbrel Fix: If the driver and firmware work but Umbrel doesn’t detect Wi-Fi, manually connect with nmcli or reinstall Umbrel on a working Ubuntu base.
Once yiou provide the diagnostic outputs, we can pinpoint which scenario applies and execute the corresponding steps.
